C2G USB Type C to DB25 Parallel Adapter Cable
Quicklinx: CMDWWS00 Mfr#: 80519
This adapter cable will connect an inkjet, laser or other parallel printer to a computer with an available USB-C port. Multiple adapters can be connected to multiple printers at the same time, eliminating the need for a switchbox. This adapter auto-negotiates hardware recognition for faster protocol setup, and is fully plug-and-play compatible. The USB-C connector has a robust design which allows for up to 10,000 connection cycles; six times more than a standard USB A connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
  • Warranty
    3 Years
  • Connector A
    USB-C Male
  • Connector B
    DB25 Female
C2G USB Type C to DB25 Parallel Adapter Cable Black - USB / parallel cable - 24 pin USB-C to DB-25
Connector
24 pin USB-C - male - reversible
Connector (Second End)
25 pin D-Sub (DB-25) - female
Rated Voltage
30 V
IEEE-1284
3-year warranty
Jacket Material
PVC
American Wire Gauge (AWG)
28
Rated Voltage
30 V
Plated Connector
Gold
62 g
Connector
IEEE-1284, Plug and Play
3-year warranty
