C2G USB 3.0 to VGA Video Adapter Converter - External video
Quicklinx: D0DVWS00 Mfr#: 81930
The USB to VGA Adapter - External Video Card is the perfect solution for adding duplicate or extended desktop to a computer utilising a USB port. The duplicate feature allows a user to show the same images from the primary display on a secondary display. This is useful in situations where a presentation must be given. The extended desktop feature allows the user to expand the desktop workspace from the primary display to both the primary and secondary display allowing different images to be shown on the two monitors. This is useful for increasing productivity when working in multiple applications or comparing data between two programs. The adapter is designed for compatibility with USB 3.0 ports. The USB 3.0 specification provides up to ten times the bandwidth of USB 2.0, which allows this adapter to support full motion video. Additionally, this adapter has a low power requirement which, when used with a mobile laptop, will allow the laptop battery to last longer. The software required for operation of the adapter is included and is easy to install and configure. Once the software is installed, up to six adapters may be connected to the computer allowing multi-display capability. High definition resolutions of up to 2560x1600 are supported and video streaming is supported at a resolution of up to 1080p.
C2G USB 3.0 to VGA Video Adapter Converter - external video adapter - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Max Resolution
2560 x 1600
Interfaces Details
VGA , USB 3.0
5.52 cm x 8.43 cm x 1.78 cm
Enclosure Colour
1-year warranty
Bus Type
SuperSpeed USB 3.0
Max Resolution
2560 x 1600
Interfaces Details
VGA , USB 3.0
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8
Additional Requirements
USB port (compatible with 3.0 specification)
1 x SuperSpeed USB cable
Software Included
Drivers & Utilities
5.52 cm
8.43 cm
1.78 cm
182 g
Enclosure Colour
Limited warranty - 1 year
10 °C
0 - 85% (non-condensing)
