C2G USB 3.0 to Gigabit Ethernet Network Adapter
Quicklinx: 9MR5WS00 Mfr#: 81693
£23.72 ex VAT
£28.46 inc VAT
The USB 3.0 to Gigabit Ethernet Network Adapter is the perfect solution for converting an existing USB 3.0 port to a Gigabit Ethernet port for connecting to a network or the Internet without replacing or adding a new network card. This adapter utilises the high bandwidth of the USB 3.0 port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply, simply connect the adapter to an available USB 3.0 port, install the included software driver and connect a Cat5 cable from the adapter to an RJ45 Network port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on new computers that do not provide a wired Ethernet port or legacy computers which have a damaged Ethernet port.
  • USB Specification
    USB 3.0
  • Housing
    Aluminium
  • Approvals
    CE compliant for RoHS2
  • Supported Operating Systems
    Windows XP, 7, 8, Mac OS10.6~10.8
C2G USB 3.0 to Gigabit Ethernet Network Adapter - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1
7.493 cm x 2.23 cm x 1.6 cm
84 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1000 Mbps
Apple MacOS X 10.6 - 10.8, Microsoft Windows 7 / Windows 8
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Data Transfer Rate
1000 Mbps
1 x 1000Base-T - RJ-45
1 x USB cable (integrated)
RoHS2
7.493 cm
2.23 cm
1.6 cm
84 g
Brand: C2G
Price Range Ex VAT: 0 - 50
