Product
C2G USB 3.0 (USB 3.1 Gen 1) USB-C to USB-A Adapter M/F - Black
Quicklinx: CHQ9WS00 Mfr#: 88868
More than 50 in stock
£8.17 ex VAT
£9.80 inc VAT
Standard delivery Delivered within 3-5 working days
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-A adapter is the perfect solution for connecting a flash drive, keyboard, mouse, or other device that has a USB A connector to a laptop or desktop computer that has a USB Type-C port for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Warranty
    Lifetime
  • Colour
C2G USB-C adapter
USB-C adapter
Sync and charge, colour-coded connectors, nickel plated shell
Connector
9 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
USB 3.0/ USB 3.1
USB-C adapter
Plated Connector
Gold
Connector
24 pin USB-C - male
USB 3.0/ USB 3.1
Brand: C2G
Price Range Ex VAT: 0 - 50
