C2G USB 2.0 USB C to USB Micro B Adapter M/F - Black
Quicklinx: CHQBWS00 Mfr#: 88869
This USB 2.0 USB-C to USB-Micro B adapter is the perfect solution for adapting an existing USB 2.0 USB-A to USB-Micro B cable for connecting the USB Type-C port of a Chromebook, laptop, smartphone or tablet to a USB-A port on a computer or other device for USB 2.0 communication, including high-speed data transfer and fast charging. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. Note: This cable is designed to supports USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
  • Lifetime warranty
    Colour: Black
C2G USB 2.0 USB C to USB Micro B Adapter M/F - USB Type C to USB Micro B Black - USB-C adapter - Micro-USB Type B to 24 pin USB-C
USB-C adapter
Sync and charge, colour-coded connectors, nickel plated shell
Connector
5 pin Micro-USB Type B - female
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C adapter
Plated Connector
Gold
Connector
24 pin USB-C - male
USB / USB 2.0
