Your basket is empty
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBCWS00 Mfr#: 81672
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
9 in stock
£19.05 ex VAT
£22.86 inc VAT
Standard delivery Delivered within 3-5 working days
With its 480 Mbps of available bandwidth, you get true 10/100 network access. The plug-and-play design makes this adapter the most convenient and efficient way to connect a laptop or desktop computer to a fast ethernet network. With our fast ethernet adapter, you can experience the full speed of your fast ethernet network without the need for opening your PC and adding internal network adapters.
Our adapter allows you to share the internet or printers, transfer files, compete in multiplayer games and more at speeds up to 200 Mbps (in full duplex mode). The portable, compact size makes it ideal for use with laptops. Hot-swappable and 100% compatible with both USB 2.0 and 1.1 hardware.
C2G USB 2.0 To Fast Ethernet Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
101 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Apple MacOS X 10.3.x or later, Microsoft Windows Vista / 2000 / XP
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Half duplex mode, full duplex mode
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable (integrated) - 19 cm
Plug and Play, RoHS
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
101 g
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: Mac
Compatibility: PC
Brand: C2G
Price Range Ex VAT: 0 - 50
