C2G TruLink 2-Port UXGA Monitor Splitter
Quicklinx: 7BD5WS00 Mfr#: 89032
£24.41 ex VAT
£29.29 inc VAT
The Trulink 2-port monitor splitter is an excellent solution for distributing video across two displays. Create a simple digital signage application or use in a conference room or classroom to broadcast computer content to multiple displays. With integrated video signal enhancement, displays can be placed up to 64 meters from the source without sacrificing video quality. This provides complete flexibility while ensuring the highest quality resolution. Multiple splitters can be added to expand the number of displays and distance.
This splitter's compact cable design makes it easy to use in tight spaces or when traveling. No drivers or additional software are required, making it quick to set up and easy to use. USB power adapter is included to power the splitter from your PC, meaning no power outlets are needed!
C2G TruLink 2-Port UXGA Monitor Splitter - video splitter - 2 ports
Video splitter - 2 ports
Subtype
VGA
Ports
2 x VGA
USB powered
136 g
1-year warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Resolution
1600 x 1200
Max Video Bandwidth
300 MHz
USB powered, signal enhancement function
2 x VGA HD-15 , 1 x VGA HD-15
1 x USB power cable
136 g
Limited warranty - 1 year
Brand: C2G
Stock Status: In stock
