Product
C2G Trulink® USB to Gigabit Ethernet Adapter
Quicklinx: 87ZHWS00 Mfr#: 81692
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: PC
Type: Network adapter
16 in stock
£23.15 ex VAT
£27.78 inc VAT
Standard delivery Delivered within 3-5 working days
The TruLink Gigabit USB 2.0 Ethernet Adapter is a cost-effective solution for converting an existing USB port to a 10/100/1000 Base-T Ethernet port without replacing or adding a new network card. With this adapter users can create a new network connection that allows them to connect to another network or computer without the need for a router or switch. The Auto Sensing feature detects the correct connection speed whether 10, 100 or 1000 Base-T. With speeds up to 480Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on older model computers that have no Ethernet port installed, so upgrades are quick and convenient. Simply plug in the adapter and load the included software driver to get 1000 Base-T connection speeds. This flexible solution requires no external power supply.
C2G USB to Gigabit Ethernet Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
Gigabit Ethernet
91 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 year warranty
Network adapter
External
USB 2.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x 1000Base-T - RJ-45
1 x USB 2.0 - 4 pin USB Type A
Software Included
Drivers & Utilities
91 g
Limited warranty - 1 year
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: C2G
Price Range Ex VAT: 0 - 50
