Make your work environment more flexible and efficient. This heavy duty 1.5mm² cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
Connector 1
(1) SEV 1011 (Swiss Power) -
Connector 2
(1) C19 IEC -
Warranty
Lifetime -
Color
Black -
Black -
Cable Length
2.00 Meter
- C2G Swiss 250 Volt 16 Amp Power Cord - power cable - IEC 60320 C19 16A to SEV 1011 - 2 m
- Power cable
- Molded
- Length
- 2 m
- Localisation
- Switzerland
- Connector
- Power IEC 60320 C19 16A
- Connector (Second End)
- Power SEV 1011 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- Rated Voltage
- AC 250 V
- Molded
- Length
- 2 m
- Black
- Localisation
- Switzerland
- Connector
- RoHS, Directive 2011/65/EU
