Using modular adapters with inexpensive satin or flat oval twisted-pair wire has become a popular way to run client server applications. Many network planners have implemented modular adapters as the most cost-effective way to complete connections. Whether used in a wiring closet or throughout the office, color-coded modular adapters from C2G lend easy identification and differentiation to your cable plan. By color coding your connections, you cut down on troubleshooting time while taking full advantage of the benefits of this modular adapter approach.
 - C2G Modular Adapter - serial adapter - RJ-45 to 15 pin D-Sub (DB-15)
 - Serial adapter
- Connector
 - RJ-45 - female
- Connector (Second End)
 - 15 pin D-Sub (DB-15) - male
 - Grey
 - Serial adapter
 - Grey
- Connector
 - RJ-45 - female
 - RoHS
