C2G RapidRun[R] Single (HD15) + 3.5mm + RCA
Quicklinx: 9NLDWS00 Mfr#: 87101
RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
Ideal for educational and institutional installations, this wall plate receives PC video, 3.5 mm stereo audio and RCA composite audio/video from one runner cable. Constructed from aluminum for durability, this wall plate has a locking connector that enables the integrator to save valuable space inside the surface mount or electrical box that typically is already packed with cables.
C2G RapidRun Single Gang Integrated HD15 + 3.5mm + RCA Audio/Video Wall Plate - wall plate - VGA / composite video / audio
Cable
Wall plate - VGA / composite video / audio
Aluminium
Connectors
HD-15 (VGA) - female , Stereo mini jack - female , RCA x 3 - female
Connectors (Second End)
MUVI connector - male
Colour-coded connectors
Cable Type
Wall plate
Interface Supported
Aluminium
Connectors
15 pin HD D-Sub (HD-15) - female , Mini-phone stereo 3.5 mm - female , RCA x 3 - female
Limited warranty - lifetime
