Product
C2G QSFP-40G-SR4 QSFP+ Transceiver
Quicklinx: CJ9MWS00 Mfr#: 89129
£471.58 ex VAT
£565.89 inc VAT
This Cisco QSFP-40G-SR4 compatible QSFP+ transceiver provides 40GBase-SR throughput up to 150m over multi-mode Fibre (MMF) at a wavelength of 850nm using a MPO connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    QSFP+ (SFF-8436)
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - QSFP+ transceiver module - 40 Gigabit LAN
QSFP+ transceiver module - MTP/MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40 Gigabit LAN
Max Transfer Distance
150 m
Cisco QSFP-40G-SR4
1.88 cm x 7.11 cm x 1.35 cm
109 g
Cisco ASR 9000 Series 1-port 40-Gigabit Ethernet Modular Port Adapter, 2-port 40-Gigabit Ethernet Modular Port Adapter; Nexus 2248PQ 10GE Fabric Extender, 3016Q, 3064-E, 3064PQ, 3064PQ Front-to-Back Airflow LAN Enterprise License Bundle, 3064-X, 6001, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E
Plug-in module
Silver
Wired
Cabling Type
40GBASE-SR
40 Gigabit LAN
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
150 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 40GBASE-SR - MTP/MPO multi-mode female
MSA
Cisco QSFP-40G-SR4
1.88 cm
7.11 cm
1.35 cm
109 g
Limited warranty - lifetime
Cisco ASR 9000 Series 1-port 40-Gigabit Ethernet Modular Port Adapter, 2-port 40-Gigabit Ethernet Modular Port Adapter , Cisco Nexus 2248PQ 10GE Fabric Extender, 3016Q, 3064-E, 3064PQ, 3064PQ Front-to-Back Airflow LAN Enterprise License Bundle, 3064-X, 6001, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E
Brand: C2G
Price Range Ex VAT: 300 - 500
