C2G MSA SFP-SX-C2G MMF Transceiver
Quicklinx: CJ16WS00 Mfr#: 89099
This SFP Transceiver Module is designed to comply with the Multiple Source Agreement (MSA) standard. This transceiver is built to meet or exceed the specifications of, and to comply with Multi-Source Agreement (MSA) standards. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Netgear AMG731F
1.27 cm x 5.59 cm x 0.76 cm
68 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
Netgear AMG731F
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
