Product
C2G Mobile Device USB Micro-B to HDMI Display SlimPort Adapter
Quicklinx: 9MR2WS00 Mfr#: 80934
8 in stock
£13.35 ex VAT
£16.02 inc VAT
Standard delivery Delivered within 3-5 working days
The USB Micro-B to HDMI SlimPort Adapter allows you to connect the USB Micro-B port of a SlimPort-enabled smartphone, tablet or other mobile device to a HDMI-equipped TV, monitor or projector supporting high resolution video up to 1080p and 7.1 channel digital audio, depending on the capabilities of both the mobile device and the display. Watch your favourite tv shows, stream high definition movies and live sports, play games and view digital content on the connected display – straight from your device. SlimPort technology makes this connection easy and does not require a driver, software or lengthy setup time. Simply connect the adapter to the Micro-B port on the SlimPort-enabled mobile device, then use a standard HDMI cable (not included) to connect from the HDMI port of the adapter to the display for a straightforward installation. Connecting a separate USB A to Micro-B cable (not included) to the adapter is not required for operation of the adapter, but may be used to charge the mobile device whilst in use.
  • Colour
  • Warranty
    1 Year
  • Connector 1
    (1) USB Micro-B Male
  • Connector 2
    (1) HDMI Female
C2G Mobile Device USB Micro-B to HDMI Display SlimPort Adapter Cable - video / audio adaptor - HDMI / USB
Cable
Video / audio adaptor - HDMI / USB
American Wire Gauge (AWG)
32
Connector
HDMI - female
Connector (Second End)
Micro-USB Type B - male
Moulded
1 year warranty
Cable Type
Interface Supported
HDMI / USB
32
Jacket Material
PVC
Plated Connector
Gold
Moulded
Connector
19 pin HDMI Type A - female
5 pin Micro-USB Type B - male
Limited warranty - 1 year
Brand: C2G
Price Range Ex VAT: 0 - 50
