C2G Mini HDMI to VGA Dongle w/Power + 3.5mm
Quicklinx: D0BSWS00 Mfr#: 80504
This HDMI Mini to VGA and Audio Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Mini-enabled Chromebook, laptop or other source device to a VGA display and set of speakers for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA and stereo audio cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Colour
  • Resolution
    Up to a 1920x1080 video resolution is supported
C2G HDMI Mini to VGA and Audio Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
Interfaces Details
Mini-HDMI , VGA
1 x HDMI input - 19 pin mini HDMI Type C , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
Interfaces Details
Mini-HDMI , VGA
39 g
Enclosure Colour
Limited warranty - lifetime
