This Enterasys MGBIC-LC03 compatible SFP transceiver provides 1000Base-MX throughput up to 2km over multi-mode Fibre (MMF) at a wavelength of 1310nm using a LC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Enterasys transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Enterasys, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
- C2G - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-MX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 2 km
- OEM Manufacturer Equivalent Part Number
- Extreme MGBIC-LC03
- 1.27 cm x 5.59 cm x 0.76 cm
- 68 g
- Limited lifetime warranty
- Designed For
- Enterasys Matrix E1; Matrix C2 Gigabit Stackable Switch C2G124-24, C2G124-48, C2G124-48P, C2H124-48; Extreme Networks ExtremeCloud E2120; Matrix E7, N3 Enterprise Switch, N7 Enterprise Switch
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-MX
- GigE
- 1 Gbps
- 1310 nm
- 2 km
- 1 x Ethernet 1000Base-MX - LC multi-mode female x 2
- MSA
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 68 g
- Limited warranty - lifetime
- Designed For
- Enterasys Matrix E1 , Enterasys Matrix C2 Gigabit Stackable Switch C2G124-24, C2G124-48, C2G124-48P, C2H124-48 , Extreme Networks ExtremeCloud E2120 , Extreme Networks Matrix E7, N3 Enterprise Switch, N7 Enterprise Switch
