Product
C2G Juniper SFP-1GE-LX-C2G SMF Transceiver
Quicklinx: CHYTWS00 Mfr#: 89079
£34.95 ex VAT
£41.94 inc VAT
This SFP (mini-GBIC) Transceiver Module is designed for use with Juniper Networks network equipment and is equivalent to Juniper Networks part number SFP-1GE-LX. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Juniper Networks and the Juniper Networks logo are trademarks or registered trademarks of Juniper Networks, Inc. This product is not certified or endorsed by Juniper Networks.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Juniper SFP-1GE-LX
1.27 cm x 5.59 cm x 0.76 cm
68 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MSA
Juniper SFP-1GE-LX
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 0 - 50
