C2G Juniper EX-SFP-1GE-LX-C2G SMF Transceiver
Quicklinx: CHYWWS00 Mfr#: 89081
This SFP (mini-GBIC) Transceiver Module is designed for use with Juniper Networks network equipment and is equivalent to Juniper Networks part number EX-SFP-1GE-LX. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Juniper Networks and the Juniper Networks logo are trademarks or registered trademarks of Juniper Networks, Inc. This product is not certified or endorsed by Juniper Networks.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
1.27 cm x 5.59 cm x 0.76 cm
68 g
Juniper Networks MX5, SRX380; EX 3200; 4200; EX Series EX4550, EX4600, EX4650, EX9204, EX9208; EX-series EX6200; MX Series MX10, MX40, MX80; MX-series MX10, MX104, MX150, MX40; NFX Series Network Services Platform NFX150, NFX350; PTX Series PTX10008; QFX Series QFX10008, QFX10016, QFX5120, QFX5200
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MSA
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
Juniper Networks MX5, SRX3600, SRX380 , Juniper Networks EX 3200 , Juniper Networks EX 4200 , Juniper Networks EX Series EX4550, EX4600, EX4650-48Y, EX9204, EX9208 , Juniper Networks EX-series EX6200 , Juniper Networks MX Series MX10, MX40, MX80 , Juniper Networks MX-series MX10, MX104, MX150, MX40, MX5, MX80 , Juniper Networks NFX Series Network Services Platform NFX150, NFX350 , Juniper Networks PTX Series PTX10008 , Juniper Networks QFX Series QFX10008, QFX10016, QFX5120-48Y, QFX5200-32C
