C2G Juniper EX-SFP-10GE-LR-C2G SMF Transceiver
Quicklinx: CHZ1WS00 Mfr#: 89083
This SFP+ Transceiver Module is designed for use with Juniper Networks network equipment and is equivalent to Juniper Networks part number EX-SFP-10GE-LR. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Juniper Networks and the Juniper Networks logo are trademarks or registered trademarks of Juniper Networks, Inc. This product is not certified or endorsed by Juniper Networks.
  • Colour
    Silver
  • Connector 1
    SFP Male+
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
1.27 cm x 5.59 cm x 0.76 cm
68 g
Juniper Networks SRX380; 5G Universal Routing Platform; EX 3200; 4200; EX Series EX4550, EX4600, EX4650, EX9204, EX9208; EX-series EX6200; MX-series MX150, MX204; NFX Series Network Services Platform NFX150, NFX350; PTX Series PTX10008; QFX Series QFX10008, QFX10016, QFX5120, QFX5200, QFX5210
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MSA
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
Juniper Networks SRX3600, SRX380 , Juniper Networks 5G Universal Routing Platform MX10003 , Juniper Networks EX 3200 , Juniper Networks EX 4200 , Juniper Networks EX Series EX4550, EX4600, EX4650-48Y, EX9204, EX9208 , Juniper Networks EX-series EX6200 , Juniper Networks MX-series MX150, MX204, MX240, MX480, MX960 , Juniper Networks NFX Series Network Services Platform NFX150, NFX350 , Juniper Networks PTX Series PTX10008 , Juniper Networks QFX Series QFX10008, QFX10016, QFX5120-32C, QFX5120-48Y, QFX5200-48Y, QFX5210-64C
