Product
C2G HP JD493A-C2G MMF Transceiver
Quicklinx: CHZLWS00 Mfr#: 89086
£32.63 ex VAT
£39.15 inc VAT
This SFP (mini-GBIC) Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD493A. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
HP JD493A
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP E4500-24; HPE 1900, 1905, 1905-10, 1905-24, 1905-48, 1910-16, 1910-24, 1910-48, 4200-12, 4210, 4210-16, 4210-24, 4210-48, 4500-24, 4500-48, 4510-24, 4510-48, 4800-24, 4800-48, E4210-48
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
HP JD493A
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
HP E4500-24-PoE , HPE 1900-8G Switch, 1905-10G-PoE Switch, 1905-24 Switch, 1905-24-PoE Switch, 1905-48 Switch, 1905-8-PoE Switch, 1910-16G Switch, 1910-24G Switch, 1910-24G-PoE (170 W) Switch, 1910-24G-PoE (365 W) Switch, 1910-48G Switch, 4200-12G Switch, 4210-16 Switch, 4210-16-PoE Switch, 4210-24 Switch, 4210-24G Switch, 4210-24G-PoE Switch, 4210-24-PoE Switch, 4210-48G Switch, 4210-8 Switch, 4210-8-PoE Switch, 4500-24 Switch, 4500-24G Switch, 4500-24G-PoE Switch, 4500-24-PoE Switch, 4500-48 Switch, 4500-48G-PoE Switch, 4500-48-PoE Switch, 4510-24G Switch, 4510-48G Switch, 4800-24G Switch, 4800-24G-PoE Switch, 4800-24G-SFP Switch, 4800-48G Switch, 4800-48G-PoE Switch, E4210-48 Switch
Brand: C2G
Price Range Ex VAT: 0 - 50
