Product
Brand
C2G HP JD094B-C2G SMF Transceiver
Quicklinx: CJ02WS00 Mfr#: 89094
£449.88 ex VAT
£539.85 inc VAT
This SFP+ Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD094B. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
C2G - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
HP JD094B
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP A5830AF-48G; HPE 12504, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5810-48G, 5900AF-48G-4XG-2QSFP+, 5900AF-48XG-4QSFP+, 5900AF-48XGT-4QSFP+, 5920AF-24XG; FlexFabric 1.92, 11908-V
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MSA
HP JD094B
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
HP A5830AF-48G Switch , HPE 12504 AC Switch Chassis, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5900AF-48G-4XG-2QSFP+ Switch, 5900AF-48XG-4QSFP+ Switch, 5900AF-48XGT-4QSFP+ Switch, 5920AF-24XG Switch , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis
Brand: C2G
Price Range Ex VAT: 300 - 500
