C2G HP JD089B-C2G RJ45 Transceiver
Quicklinx: CHZPWS00 Mfr#: 89088
£48.26 ex VAT
£57.91 inc VAT
This SFP (mini-GBIC) Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD089B. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a copper network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    RJ-45 Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
HP JD089B
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP 3100-8-PoE v2; HPE 10512, 12504, 1910-8G, 1910-8G-PoE+, 3100-24 V2, 3100-24-PoE v2, 3100-8 v2, 3600-24 v2, 3600-24-PoE+ v2, 3600-24-SFP v2, 3600-48-PoE+ v2, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5920AF-24XG, 7506; FlexFabric 1.92, 11908-V, 12902E
Plug-in module
Silver
Wired
Cabling Type
1000Base-TX
GigE
Data Transfer Rate
1 Gbps
100 m
1 x Ethernet 1000Base-TX - RJ-45 female
MSA
HP JD089B
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
HP 3100-8-PoE v2 EI Switch , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-24 V2 EI Switch, 3100-24-PoE v2 EI Switch, 3100-8 v2 SI Switch, 3600-24 v2 EI, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP v2 EI, 3600-48-PoE+ v2 SI, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5920AF-24XG Switch, 7506 , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis
Brand: C2G
Price Range Ex VAT: 0 - 50
