This HDMI to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the HDMI output port of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
- C2G HDMI to VGA Adapter Converter Dongle - video converter - black
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15)
- Enclosure Colour
- Black
- Limited lifetime warranty
- Video converter
- Max Resolution
- 1920 x 1080
- 44 g
- Enclosure Colour
- Black
- Limited warranty - lifetime
- 0 °C
- 70 °C
