C2G HDMI to VGA Adapter Converter Dongle - 10 Pack
Quicklinx: FGHDWS00 Mfr#: 80500?BT
13 in stock
£146.40 ex VAT
£175.68 inc VAT
This adapter converter dongle is an ideal solution for connecting the video output of a HDMI-enabled laptop to a VGA display. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter. Up to a 1920x1080 video resolution is supported, allowing this adapter converter to meet the needs of a high performance application. Connect this adapter directly to the output of a laptop and use a VGA cable to connect to a display.
  • Colour
  • Resolution
C2G HDMI to VGA Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
44 g
Enclosure Colour
Limited warranty - lifetime
70 °C
Brand: C2G
Stock Status: In stock
