Product
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6WS00 Mfr#: 81698
14 in stock
£37.46 ex VAT
£44.95 inc VAT
Standard delivery Delivered within 3-5 working days
The HDMI to DisplayPort Adapter Converter allows you to connect an HDMI source device, such as your laptop or Blu-ray player, to a monitor or display with a DisplayPort input, delivering high quality video up to a maximum resolution of 1920x1200. This Converter is the perfect solution for connecting older HDMI-enabled devices that do not support a DisplayPort output to more modern, DisplayPort-equipped monitors and displays; a functionality that is not supported by other adapters that are designed to connect the DisplayPort output of a device to a display which accepts an HDMI input. Additionally, this converter supports HDCP.
  • Colour
  • Warranty
    1 Year
C2G HDMI to DisplayPort Converter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort
8.15 cm x 4.2 cm x 2.3 cm
Enclosure Colour
1 year warranty
Video converter
Max Resolution
1920 x 1200
HDCP
RoHS2
8.15 cm
4.2 cm
2.3 cm
367 g
Enclosure Colour
Limited warranty - 1 year
-10 °C
50 °C
Brand: C2G
Price Range Ex VAT: 0 - 50
