Your basket is empty
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6WS00 Mfr#: 81698
7 in stock
£33.52 ex VAT
£40.22 inc VAT
Standard delivery Delivered within 3-5 working days
The HDMI to DisplayPort Converter is the perfect solution for connecting devices with an HDMI output to a display with a DisplayPort input. The HDMI to DisplayPort Converter provides functionality that is not supported by other adapters that are designed to connect the DisplayPort output of a device and to a display which accepts an HDMI input. This Converter extends the life of a device, such as a Blu-ray player, which does not support a DisplayPort output by allowing it to be connected to a new display which accepts a DisplayPort input. The HDMI to DisplayPort Converter supports a maximum resolution of 1920x1200 and supports HDCP.
C2G HDMI to DisplayPort Converter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort
8.15 cm x 4.2 cm x 2.3 cm
Enclosure Colour
1 year warranty
Video converter
Max Resolution
1920 x 1200
HDCP
RoHS2
8.15 cm
4.2 cm
2.3 cm
367 g
Enclosure Colour
Limited warranty - 1 year
-10 °C
50 °C
Brand: C2G
Price Range Ex VAT: 0 - 50
