The HDMI over Cat5 Receiver, when paired with a transmitter, allows for the extension of an HDMI signal over solid conductor Cat5e/6 twisted pair cable up to 100m (330ft) without signal degradation at a 1080p video resolution. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. In addition, this solution utilises TruChoice Power which provides the flexibility to power the system with a single power supply at either the transmitter or receiver end. HDBaseT technology allows the Extended Display Identification Data (EDID) signals, i.e. communication of the display's capabilities, to pass through the extension solution ensuring that the content from the source is sent at the optimal resolution for the display. Built-in power surge protection and high ground loop immunity ensure high performance signal extension. The HDMI over Cat5 extenders support advanced HDMI features such as 3D, auto lip sync, deep color, Dolby & DTS 7.1 audio, CEC and a 10.2 Gbps data transfer rate.
- C2G TruLink HDMI over Cat5 Box Receiver - video/audio extender - HDMI - TAA Compliant
- Video/audio extender (receiver)
- Form Factor
- External
- Data Link Protocol
- HDMI
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 100 m
- 11 cm x 6.5 cm x 0.9 cm
- 0.54 kg
- TAA Compliant
- 3-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- HDMI
- Max Resolution
- 1080p
- 100 m
- 7.1 channel audio support
- 1 x display / video - HDMI input - 19 pin HDMI Type A female , 1 x network - RJ-45 female
- Mounting Kit
- Included
- FCC, RoHS
- TAA Compliant
- 11 cm
- 6.5 cm
- 0.9 cm
- 0.54 kg
- Limited warranty - 3 years
