C2G HDMI Micro Male to HDMI Female Adapter Converter Dongle
Quicklinx: 9Y4HWS00 Mfr#: 80510
£9.16 ex VAT
£10.99 inc VAT
This HDMI Micro to HDMI Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Micro-enabled Chromebook, laptop or other source device to the HDMI input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output port of a Chromebook or laptop and use a standard HDMI cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Colour
  • Resolution
    Up to a 1080p video resolution is supported
C2G HDMI Micro to HDMI Adapter Converter Dongle - HDMI adapter - 20.3 cm
Cable
HDMI adapter
Double shielded
American Wire Gauge (AWG)
34
Length
20.3 cm
Connector
HDMI - female
Connector (Second End)
19 pin micro HDMI Type D - male
Cable Type
HDMI adapter
Double shielded
34
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Length
20.3 cm
Connector
19 pin HDMI Type A - female
Limited warranty - lifetime
