C2G HDBaseT HDMI + USB Over Cat5 Extender Video/Audio/Infrared/USB/Serial Extender HDBaseT 2.0
Quicklinx: CNDLWS00 Mfr#: 89510
£639.04 ex VAT
£766.84 inc VAT
The HDBaseT HDMI + USB over cat5 extender is the perfect solution for long distance delivery of audio, video and USB signals from a computer or media player to an interactive whiteboard, touch screen, digital signage or other interactive display requiring high quality ULTRA HD video resolutions of up to 4K at 60Hz (2160p) at distances of up to 100 metres (328 feet). This HDBaseT HDMI + USB over Cat5 extender functions as an interface point for remote terminals, which provides a straightforward solution to control remote devices. With 4K HDMI AV output and four USB ports, this kit allows for multiple USB devices such as a touch screen, conference camera, mouse or keyboard next to an HDMI display to be installed in a remote location. With no drivers or software to install, the HDMI + USB over Cat5 Extender provides total plug and play convenience, passes EDID and HDCP and supports all USB 2.0 functionality. Simply run two solid Cat5e or Cat6 cables up to 100 metres (328 feet) between the transmitter at the source and the receiver at the display, connect all applicable devices, connect the power adapter and turn power on for all devices. The extender also extends IR and Serial control up to 100 metres using a standard remote.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (1) HDMI Female, (1) RJ-45 Female, (1) Toslink Female, (1) RJ-11 Female, (1) USB Mini-B Female, (1) 3.5mm Stereo Female, (2) 3.5mm Mono Female
  • Connector 2
    (1) HDMI Female, (1) RJ-45 Female, (1) Toslink Female, (1) RJ-11 Female, (1) USB-A Female, (1) 3.5mm Stereo Female, (2) 3.5mm Mono Female
C2G HDBaseT HDMI + USB Over Cat5 Extender - video/audio/infrared/USB/serial extender - HDBaseT 2.0
Video/audio/infrared/USB/serial extender
Desktop
HDBaseT 2.0
Max Transfer Distance
100 m
AC 120/230 V
9.8 cm x 10.2 cm x 2.8 cm
1.6 kg
3-year warranty
Desktop
Wired
HDBaseT 2.0
100 m
Status Indicators
Status
Firmware upgradable, wall mountable, 4K resolution support, EDID Pass-Through, Dolby TrueHD support, DTS-HD Master Audio support, DTS support
USB 1.1, USB 2.0, HDCP 2.2
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female , 1 x TOSLINK (input) female , 1 x TOSLINK (output) female , 1 x RS-232 (input) - RJ-11 female , 1 x RS-232 (output) - RJ-11 female , 1 x audio (input) - mini jack female , 1 x audio (output) - mini jack female , 2 x IrDA (input) female , 2 x IrDA (output) female , 1 x mini-USB (power) - Type B female , 4 x USB 2.0 - Type A female
IR extender, IR receiver, foot pad set
1 x mini-USB to USB cable , 2 x DB-9 to RJ-11 adapter , Serial cable , RJ-11 phone cable
Mounting Kit
Included
VCCI, FCC, RoHS2
External power adapter
AC 120/230 V (50 - 60 Hz)
9.8 cm
10.2 cm
2.8 cm
1.6 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Brand: C2G
Price Range Ex VAT: 500 - 750
