C2G FTLF8524P2BNL SFP (min-GBIC) Transceiver
Quicklinx: CJ9GWS00 Mfr#: 89124
This Finisar FTLF8524P2BNL compatible SFP transceiver provides 1/2/4Gbs Fibre Channel-SW throughput up to 150m over multi-mode Fibre (MMF) at a wavelength of 850nm using a LC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Finisar transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Finisar, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - Fibre Channel, 2Gb Fibre Channel, 4Gb Fibre Channel
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
Fibre Channel
Data Transfer Rate
4 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
150 m
1.27 cm x 5.59 cm x 0.76 cm
68 g
Plug-in module
Silver
Wired
Cabling Type
Fibre Channel
Data Transfer Rate
4 Gbps
Optical Wave Length
850 nm
150 m
1 x 4Gb Fibre Channel - LC multi-mode female x 2
MSA
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
