This XFP Transceiver Module is designed for use with Force10 network equipment and is equivalent to Force10 part number GP-XFP-1S. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Force10 and the Force10 logo are trademarks or registered trademarks of Dell, Inc. This product is not certified or endorsed by Dell.
- C2G - XFP transceiver module - 10 GigE
- XFP transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10 GigE
- Max Transfer Distance
- 300 m
- OEM Manufacturer Equivalent Part Number
- Force10 GP-XFP-1S
- 1.27 cm x 6.35 cm x 0.76 cm
- 90.7 g
- Limited lifetime warranty
- Designed For
- Dell Force10 C300 Resilient Switch, S25P Access Switch, S50 High Performance Data Center Switch, S50V Access Switch; Force10 TeraScale E-Series E1200, E300, E600; Force10 E600i
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10 GigE
- 10 Gbps
- 850 nm
- 300 m
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- MSA
- Force10 GP-XFP-1S
- 1.27 cm
- 6.35 cm
- 0.76 cm
- 90.7 g
- Limited warranty - lifetime
- Designed For
- Dell Force10 C300 Resilient Switch, S25P Access Switch, S50 High Performance Data Center Switch, S50V Access Switch , Dell Force10 TeraScale E-Series E1200, E300, E600 , Force10 E600i
