C2G EX-XFP-10GE-LR XFP Transceiver
Quicklinx: CJ18WS00 Mfr#: 89101
This Juniper Networks EX-XFP-10GE-LR compatible XFP transceiver provides 10GBase-LR throughput up to 10km over single-mode Fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Juniper Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Juniper Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    XFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - XFP transceiver module - 10 GigE
XFP transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
Juniper EX-XFP-10GE-LR
1.27 cm x 6.35 cm x 0.76 cm
90.7 g
Juniper Networks SRX3600; EX 3200
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MSA
1.27 cm
6.35 cm
0.76 cm
90.7 g
Limited warranty - lifetime
Juniper Networks SRX3600 , Juniper Networks EX 3200
