This Juniper Networks EX-SFP-1GE-T compatible SFP transceiver provides 1000Base-TX throughput up to 100m over a copper connection using a RJ-45 connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Juniper Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Juniper Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
- C2G - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-TX
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- GigE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- Juniper EX-SFP-1GE-T
- 1.27 cm x 5.59 cm x 0.76 cm
- 68 g
- Limited lifetime warranty
- Designed For
- Juniper Networks SRX3600, SRX380; EX 3200; EX Series EX4550, EX4600, EX4650-48Y, EX9204, EX9208; EX-series EX6200; MX-series MX150, MX204; NFX Series Network Services Platform NFX350; PTX Series PTX10008; QFX Series QFX10008, QFX10016, QFX5120-48Y, QFX5200-32C
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-TX
- GigE
- 1 Gbps
- 100 m
- 1 x Ethernet 1000Base-TX - RJ-45 female
- MSA
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 68 g
- Limited warranty - lifetime
- Designed For
- Juniper Networks SRX3600, SRX380 , Juniper Networks EX 3200 , Juniper Networks EX Series EX4550, EX4600, EX4650-48Y, EX9204, EX9208 , Juniper Networks EX-series EX6200 , Juniper Networks MX-series MX150, MX204 , Juniper Networks NFX Series Network Services Platform NFX350 , Juniper Networks PTX Series PTX10008 , Juniper Networks QFX Series QFX10008, QFX10016, QFX5120-48Y, QFX5200-32C
