C2G DVI-D™ M/F Port Saver Adapter
Quicklinx: 6860WS00 Mfr#: 81530
£7.80 ex VAT
£9.36 inc VAT
DVI adapters from C2G deliver the high performance, high-bandwidth interface needed for a connection between PCs and flat panel displays, digital CRT displays, projectors, and HDTV. The DVD-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 and is designed for high-speed digital use. These precision-engineered adapters are fully compliant with the DVI standard defined by DDWG (Digital Display Working Group).
C2G DVI adapter
DVI adapter - dual link
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
RoHS
DVI adapter
TMDS Links
Dual link
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
RoHS
Brand: C2G
Price Range Ex VAT: 0 - 50
