C2G DVI-A Male to HD15 VGA Female Video Adapter
Quicklinx: 63PCWS00 Mfr#: 81222
Digital Visual Interface (DVI) is the standard interface for high-performance connection between desktop PCs and flat panel displays, CRT displays, projectors, and HDTV. This analog video adapter is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-A analog configuration adapts an existing VGA cable for use with an analog DVI-I device.
C2G VGA adapter
VGA adapter
Connector
DVI-I - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA adapter
Plated Connector
Gold
Connector
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
RoHS
