C2G DVI-A Female to HD15 VGA Male Video Adapter
Quicklinx: 63Q4WS00 Mfr#: 81221
24 in stock
£8.61 ex VAT
£10.33 inc VAT
Digital Visual Interface (DVI) is the standard interface for high-performance connection between desktop PCs and flat panel displays, CRT displays, projectors, and HDTV. This analog video adapter is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-A analog configuration adapts an existing VGA cable for use with an analog DVI-I device. Maximum resolution is UXGA (1600 pixels x 1200 pixels). Gold-plated contacts provide full conductivity with no data loss. PC- and Mac-compatible cable supports hot-plugging of DVI display devices.
  • Warranty
    Lifetime
  • Colour
    Blue
C2G VGA adapter
VGA adapter
Connector
DVI-A - female
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA adapter
Plated Connector
Gold
Connector
12+5 pin analogue DVI - female
RoHS
Brand: C2G
Price Range Ex VAT: 0 - 50
