C2G DB9 Male to DB25 Male Serial Adapter
Quicklinx: 683XWS00 Mfr#: 81445
Use existing serial or modem cables and serial adapters from C2G to convert existing DB9 ports to DB25 or vice versa. Serial adapters are an inexpensive alternative to buying new cables. With their molded design providing a solid connection, each adapter is shielded against outside EMI/RFI interference while giving you the flexibility to meet your connectivity needs.
C2G - serial adapter - DB-9 to DB-25
Serial adapter
Shielded
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
25 pin D-Sub (DB-25) - male
Serial adapter
Shielded
Connector
RoHS
