DB9 gender changers from C2G will quickly and easily convert the gender of any parallel, serial, game/midi or video port. In addition, they can be used to splice together two existing cables. Save yourself the cost and hassle of having to buy a cable for each application; simply change the gender of your existing port and use the very same cable.
- C2G - serial gender converter - DB-9 to DB-9
- Serial gender converter
- Technology
- Shielded
- Molded
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- Technology
- Shielded
- Molded
- Connector
- RoHS
