C2G DB9 M/F Null Modem Adapter
Quicklinx: 6841WS00 Mfr#: 81449
Convert your existing serial cables into null modem cables using null modem adapters from C2G. A quick and easy fix for your DTE or DCE incompatibilities, connecting two RS232 serial ports has never been so easy. Each cable will effectively cross the data transmission lines.
C2G - null modem adapter - DB-9 to DB-9
Null modem adapter
Shielded
Molded
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
Null modem adapter
Shielded
Molded
Grey
Connector
RoHS
