C2G DB9 M/F Null Modem Adapter
Quicklinx: 6841WS00 Mfr#: 81449
Hurry, only 1 left in stock!
£4.94 ex VAT
£5.92 inc VAT
Convert your existing serial cables into null modem cables using null modem adapters from C2G. A quick and easy fix for your DTE or DCE incompatibilities, connecting two RS232 serial ports has never been so easy. Each cable will effectively cross the data transmission lines.
C2G null modem adapter
Null modem adapter
Shielded
Molded
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
Null modem adapter
Shielded
Molded
Grey
Connector
RoHS
Brand: C2G
Price Range Ex VAT: 0 - 50
