Brand
C2G DB9 Female to DB25 Female Serial Adapter
Quicklinx: 63NCWS00 Mfr#: 81442
Use existing serial or modem cables and serial adapters from C2G to convert existing DB9 ports to DB25 or vice versa. Serial adapters are an inexpensive alternative to buying new cables. With their molded design providing a solid connection, this adapter is shielded against outside EMI/RFI interference while giving you the flexibility to meet your connectivity needs.
C2G - serial adapter - DB-9 to DB-25
Serial adapter
Shielded
Molded
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - female
Serial adapter
Shielded
Molded
Connector
RoHS
