Product
C2G Cisco WS-G5484-C2G MMF Transceiver
Quicklinx: CHYPWS00 Mfr#: 89074
£35.55 ex VAT
£42.66 inc VAT
This GBIC Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number WS-G5484. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
  • Colour
    Silver
  • Connector 1
    GBIC Male
  • Connector 2
    SC Female
  • Warranty
    Lifetime
C2G - GBIC transceiver module - GigE
GBIC transceiver module - SC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Cisco WS-G5484
3.05 cm x 6.6 cm x 1.02 cm
27.2 g
Cisco Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4418, 4500, 4912; Network Processing Engine G1, uBR7200; Node Route Processor 2SV; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - SC multi-mode female x 2
MSA
Cisco WS-G5484
3.05 cm
6.6 cm
1.02 cm
27.2 g
Limited warranty - lifetime
Cisco Catalyst 2912MF, 2912MF-XL, 2912MF-XL Enterprise Edition, 2924M, 2924M-XL, 2924M-XL DC, 2924M-XL Enterprise Edition, 2948G, 2948G-GE-TX Gigabit Ethernet Switch, 2948G-L3, 2950G-12, 2950G-24, 2950G-24-EI, 2950G-48, 2950G-48-EI, 2980G, 2980G-A, 3508G XL Enterprise Edition, 3512 XL Enterprise Edition, 3512G XL Enterprise Edition, 3512XL Standard Edition, 3524-PWR XL Enterprise Edition, 3524XL Enterprise Edition, 3548XL Enterprise Edition, 3550-12G, 3550-12T, 3550-24 EMI, 3550-24 PWR EMI, 3550-24 PWR SMI, 3550-24 SMI, 3550-48 EMI, 3550-48 SMI, 4418, 4500 Series Supervisor Engine V-10GE, 4912G , Cisco Network Processing Engine G1, uBR7200-NPE-G1 , Cisco Node Route Processor 2SV , Cisco Supervisor Engine 1A 2GE, 1A 2GE Plus, 1A 2GE Plus MSFC & PFC, 1A 2GE Plus PFC, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10GE
Brand: C2G
Price Range Ex VAT: 0 - 50
