This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number SFP-GE-T. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a copper network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
- C2G Cisco SFP-GE-T Compatible 1000Base-T Copper SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- GigE
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-GE-T
- 62 g
- Limited lifetime warranty
- Designed For
- Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 93108TC-EX, 93180YC-FX, 9372PX-E
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- GigE
- 1 Gbps
- 1 x Ethernet 1000Base-T - RJ-45 female
- MSA
- Cisco SFP-GE-T
- 62 g
- Limited warranty - lifetime
- Designed For
- Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Nexus 93108TC-EX, 93180YC-FX, 9372PX-E
