Product
C2G Cisco SFP-GE-T Compatible SFP RJ45 (mini-GBIC) Transceiver
Quicklinx: C5TNWS00 Mfr#: 88610
£46.76 ex VAT
£56.11 inc VAT
This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number SFP-GE-T. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a copper network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    RJ-45 Female
  • Warranty
    Lifetime
C2G Cisco SFP-GE-T Compatible 1000Base-T Copper SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
GigE
Cisco SFP-GE-T
62 g
Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
GigE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T - RJ-45 female
MSA
Cisco SFP-GE-T
62 g
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 0 - 50
