C2G Cisco SFP-10G-SR-C2G MMF Transceiver
Quicklinx: CHYJWS00 Mfr#: 89070
This SFP+ Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number SFP-10G-SR. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
  • Colour
    Silver
  • Connector 1
    SFP+ Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
Cisco SFP-10G-SR
1.27 cm x 5.59 cm x 0.76 cm
68 g
P/N: A99-4HG-FLEX-TR=, ASR1000-MIP100-PR=, C8500-20X6C, C9300X-24HX-1A, FPR3105-ASA-K9, FPR3105-NGFW-K9, FPR3140-ASA-K9, FPR4215-ASA-K9, FPR4215-NGFW-K9, FPR4225-NGFW-K9, FPR4245-NGFW-K9, HCI-FI-6454-M6, N9K-C9348GC-FX3, NC57-MPA-12L-S-FC=, NCS-57C1-48Q6D-S, UCS-FI-64108-D-U, UCSX-FI-6536-NEW
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MSA
Cisco SFP-10G-SR
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
P/N: A900-IMA8CS1Z-M=, A9903-8HG-PEC=, A99-48X10GE-1G-SE=, A99-48X10GE-1G-TR=, A99-4HG-FLEX-SE=, A99-4HG-FLEX-TR=, A9K-24P-80G-SE-B=, A9K-24P-80G-TR-B=, A9K-24X10GE-1G-CM=, A9K-24X10GE-1G-SE, A9K-24X10GE-1G-SE=, A9K-48X10GE-1G-CM=, A9K-48X10GE-1G-SE=, A9K-48X10GE-TEL-BN, A9K-MPA20X10GE-CM=, ASR1000-MIP100-PR=, C2960X-FIBER-STK, C2960X-HYBRID-STK, C8500-20X6C, C9200-NM-4X, C9300-24H-1A, C9300-24H-EDU, C9300-24U-10E, C9300-24UX-10A, C9300-24UXB-A, C9300-48H-1A, C9300-48U-10A, C9300-48UB-A, C9300-48UB-E, C9300-48UN-EDU, C9300-48UXM-A-CAP, C9300-NM-2Y, C9300X-24HX-1A, C9400-LC-24XS, C9400-SUP-1XL, C9500-16X-1A, C9500-16X-1E, C9500-16X-2Q-A, C9500-16X-2Q-E, C9500-16X-A, C9500-16X-E, C9500-16X-EDU, C9500-24X-A, C9500-24X-E, C9500-40X-10A, C9500-40X-10E, C9500-40X-1A, C9500-40X-1E, C9500-40X-2Q-E, C9500-40X-EDU, C9500-40X-P, C9500-48X-A, C9500-48X-E, CBR-DPIC-8X10G=, DN-APL-TTA-M, FPR1150-ASA-K9, FPR1150-NGFW-K9, FPR3105-ASA-K9, FPR3105-NGFW-K9, FPR3140-ASA-K9, FPR4112-ASA-K9, FPR4112-NGFW-K9, FPR4112-NGIPS-K9, FPR4115-ASA-K9, FPR4115-NGIPS-K9, FPR4125-ASA-K9, FPR4125-NGFW-K9, FPR4125-NGIPS-K9, FPR4145-ASA-K9, FPR4145-NGFW-K9, FPR4145-NGIPS-K9, FPR4215-ASA-K9, FPR4215-NGFW-K9, FPR4225-NGFW-K9, FPR4245-NGFW-K9, HCI-FI-6454-M6, HX-FI-64108, HX-FI-6454, N3K-C3264C-E, N3K-C34180YC, N3K-C3524P-XL, N3K-C3548P-XL, N3K-C36180YC-R, N9K-C92300YC, N9K-C9316D-GX, N9K-C93240YC-FX2, N9K-C9332C, N9K-C9336C-FX2, N9K-C9348GC-FX3, N9K-C93600CD-GX, N9K-C9364C-GX, N9K-X96136YC-R, N9K-X9732C-FX, N9K-X9736C-EX, N9K-X9736C-FX, N9K-X9788TC-FX, NC55-24H12F-SB=, NC55-24X100G-SB=, NC55-36X100G-SB=, NC55-36X100G-U-BA=, NC55-36X100G-U-SB=, NC-55-MOD-A=, NC55-MOD-A-BM=, NC-55-MOD-A-SE=, NC55-MOD-A-SM=, NC55-MPA-12T-S, NC55-MPA-12T-S=, NC57-MPA-12L-S-FC=, NCS4200-1T16G-PS=, NCS-5001-BUN, NCS-5002-BUN, NCS-5002-SAT1G-BUN, NCS-57C1-48Q6D-S, UCS-FI-64108, UCS-FI-64108-D-U, UCS-FI-64108-U, UCS-FI-6454, UCS-FI-6454-U, UCSX-FI-6536-NEW, WS-X45-SUP9-E
