Product
Brand
C2G Cisco SFP-10G-LRM-C2G MMF Transceiver
Quicklinx: CHYLWS00 Mfr#: 89072
£307.00 ex VAT
£368.40 inc VAT
This SFP+ Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number SFP-10G-LRM. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page.
C2G - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-LRM
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
220 m
Cisco SFP-10G-LRM
1.27 cm x 5.59 cm x 0.76 cm
68 g
P/N: A9K-16T/8-B=, ME-3600X-24FS-M, ME-3600X-24FS-M=, ME-3600X-24TS-M, ME-3600X-24TS-M=, ME-3800X-24FS-M, N7K-F132XP-15, N7K-F132XP-15=, N7K-M132XP-12L, N7K-M132XP-12L=, WS-C4948E-F, WS-X45-SUP7-E/2, WS-X45-SUP7-E=, WS-X45-SUP7L-E, WS-X45-SUP7L-E/2, WS-X45-SUP7L-E=, WS-X4712-SFP+E, WS-X4712-SFP+E=
Plug-in module
Silver
Wired
Cabling Type
10GBase-LRM
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
220 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
MSA
Cisco SFP-10G-LRM
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
P/N: A9K-16T/8-B, A9K-16T/8-B=, ME-3600X-24FS-M, ME-3600X-24FS-M=, ME-3600X-24TS-M, ME-3600X-24TS-M=, ME-3800X-24FS-M, N7K-F132XP-15, N7K-F132XP-15=, N7K-M132XP-12L, N7K-M132XP-12L=, WS-C4948E-E, WS-C4948E-F, WS-C4948E-S, WS-X45-SUP7-E, WS-X45-SUP7-E/2, WS-X45-SUP7-E=, WS-X45-SUP7L-E, WS-X45-SUP7L-E/2, WS-X45-SUP7L-E=, WS-X4712-SFP+E, WS-X4712-SFP+E=
Brand: C2G
Price Range Ex VAT: 300 - 500
