This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number GLC-SX-MMD. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
- C2G Cisco GLC-SX-MMD Compatible 1000BASE-SX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 550 m
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-SX-MMD
- 54 g
- Limited lifetime warranty
- Designed For
- Cisco 38XX, 38XX V3PN, 7301, 7301 VAM2+; Catalyst 29XX, 3560, 3750, 4500, 4948; Catalyst Compact 2960; Catalyst Express 500; CSS 11XXX; Integrated Services Router 11XX; ME 3400, 4924, 6524; Nexus 93XX, 93XXX; Supervisor Engine 720, II-Plus-TS
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- GigE
- 1 Gbps
- 850 nm
- 550 m
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
- MSA
- Cisco GLC-SX-MMD
- 54 g
- Limited warranty - lifetime
- Designed For
- Cisco 3825, 3825 Branch Office in a Box Bundle, 3825 HVSEC Bundle, 3825 ISR IP Video Surveillance Bundle, 3825 Retail Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 Video Encoding Bundle, 3825 VSEC Bundle, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3825C, 3845, 3845 Branch Office in a Box Bundle, 3845 HVSEC Bundle, 3845 ISR IP Video Surveillance Bundle, 3845 Unified Communications Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 Video Encoding Bundle, 3845 VSEC Bundle, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 3845C, 7301 VAM2+ Router Security Bundle , Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC-L, 2960-48TC-S, 2960-8TC-S, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560-12PC, 3560-12PC-S, 3560-24TS, 3560-48TS, 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560G-48, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3560X-24P-E, 3560X-24P-L, 3560X-24P-S, 3560X-24T-10G, 3560X-24T-E, 3560X-24T-L, 3560X-24T-S, 3560X-24U-E, 3560X-48P-E, 3560X-48PF-10G, 3560X-48PF-E, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-E, 3560X-48T-L, 3560X-48T-S, 3560X-48U-E, 3560X-48U-L, 3560X-48U-S, 3750G-12S-S, 3750G-24PS-E, 3750G-24PS-S, 3750G-48PS-E, 3750G-48PS-S, 3750G-48TS-E, 3750G-48TS-S , Cisco Catalyst Compact 2960C-8TC-L , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco ME 4924-10GE, 6524 Ethernet Switch , Cisco Nexus 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E
