C2G Cisco GLC-LH-SMD Compatible SFP (mini-GBIC) Transceiver
Quicklinx: C5TLWS00 Mfr#: 88608
This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number GLC-LH-SMD. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Cisco GLC-LH-SMD Compatible 1000Base-LX SMF SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Cisco GLC-LH-SMD
57 g
Cisco 38XX, 39XX, 4451, 8, 892; ASR 901 10; Catalyst 29XX, 3560, 3650, 3750, 4500, 6900, ESS9300; Industrial Ethernet 2000; Integrated Services Router 11XX; Line Card E-Series; ME 3600, 3600X 24, 3800; Nexus 30XX, 7000, 93180, 93XX; Supervisor Engine 7L, 8; UCS 62XX
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MSA
Cisco GLC-LH-SMD
57 g
Limited warranty - lifetime
Cisco 3825, 3825 Branch Office in a Box Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3825C, 3845, 3845 Branch Office in a Box Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 3845C, 3925, 3925 Application Experience, 3925 Generation 2 STM-1 Bundle, 3925E, 3925E Application Experience, 3925E Generation 2 STM-1 Bundle, 3945, 3945 Application Experience, 3945 Generation 2 STM-1 Bundle, 3945E, 3945E Generation 2 STM-1 Bundle, 4451-X, 4451-X Application Experience, 4451-X Integrated Services Router, 4451-X Integrated Services Router Security Bundle, 4451-X Integrated Services Router Voice and Video Bundle, 4451-X Integrated Services Router Voice Security Bundle, 892 , Cisco Catalyst 2960-Plus 24LC-L, 2960-Plus 24LC-S, 2960-Plus 24PC-L, 2960-Plus 24PC-S, 2960-Plus 24TC-L, 2960-Plus 24TC-S, 2960-Plus 48PST-L, 2960-Plus 48PST-S, 2960-Plus 48TC-L, 2960-Plus 48TC-S, 3650-24PD-E, 3650-24PD-L, 3650-24PD-S, 3650-24PS-E, 3650-24PS-L, 3650-24PS-S, 3650-24TD-E, 3650-24TD-L, 3650-24TD-S, 3650-24TS-E, 3650-24TS-L, 3650-24TS-S, 3650-48FD-E, 3650-48FD-L, 3650-48FD-S, 3650-48FQ-E, 3650-48FQ-L, 3650-48FQ-S, 3650-48FS-E, 3650-48FS-L, 3650-48FS-S, 3650-48PD-E, 3650-48PD-L, 3650-48PD-S, 3650-48PQ-E, 3650-48PQ-L, 3650-48PQ-S, 3650-48PS-E, 3650-48PS-L, 3650-48PS-S, 3650-48TD-E, 3650-48TD-L, 3650-48TD-S, 3650-48TQ-E, 3650-48TQ-L, 3650-48TQ-S, 3650-48TS-E, 3650-48TS-L, 3650-48TS-S, ESS9300 Embedded Series , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco ME 3600X-24FS Ethernet Access Switch , Cisco Nexus 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco Supervisor Engine 8-E, 8-E Redundant , Cisco UCS 6248UP Fabric Interconnect
