C2G Cisco GLC-FE-100FX-RGD Compatible SFP mini-GBIC Transceiver
Quicklinx: C5TGWS00 Mfr#: 88605
This Cisco GLC-FE-100FX-RGD compatible SFP transceiver provides 100Base-FX throughput up to 2km over multi-mode fibre (MMF) at a wavelength of 1310nm using a LC connector. It is also capable of withstanding rugged environments and can operate at temperatures between -40[D]C to +85[D]C. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Cisco GLC-FE-100FX-RGD Compatible 100BASE-FX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
1.27 cm x 5.59 cm x 0.76 cm
30 g
P/N: A900-IMA8S1Z, IE-2000U-4S-G, IE-4000-16GT4G-E, IE-4000-16T4G-E, IE-4000-4GS8GP4G-E, IE-4000-4S8P4G-E, IE-4000-4TC4G-E, IE-4000-8GS4G-E, IE-4000-8GT4G-E, IE-4000-8GT8GP4G-E, IE-4000-8S4G-E, IE-4010-16S12P, IE-4010-4S24P, IE-5000-16S12P, IR1821-K9, IR1831-K9, IR1833-K9, IR1835-K9
Plug-in module
Silver
Wired
Cabling Type
100Base-FX
100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
1 x Ethernet 100Base-FX - LC multi-mode female x 2
MSA
1.27 cm
5.59 cm
0.76 cm
30 g
Limited warranty - lifetime
-40 °C
85 °C
P/N: A900-IMA8S, A900-IMA8S=, A900-IMA8S1Z, A900-IMA8T, A901-4C-F-D, A901-4C-FT-D, A901-6CZ-F-A, A901-6CZ-F-A-RF, A901-6CZ-F-D, A901-6CZ-FT-A, A901-6CZ-FT-D, ASR-920-24SZ-M, GRWIC-D-ES-2S-8PC, GRWIC-D-ES-6S, IE-2000-16PTC-G-E, IE-2000-16PTC-G-L, IE-2000-16PTC-G-NX, IE-2000-16TC-B, IE-2000-16TC-G-E, IE-2000-16TC-G-L, IE-2000-16TC-G-N, IE-2000-16TC-G-X, IE-2000-16TC-L, IE-2000-4S-TS-G-B, IE-2000-4S-TS-G-L, IE-2000-4TS-B, IE-2000-4TS-G-B, IE-2000-4TS-G-L, IE-2000-4TS-L, IE-2000-8TC-B, IE-2000-8TC-G-B, IE-2000-8TC-G-E, IE-2000-8TC-G-L, IE-2000-8TC-G-N, IE-2000-8TC-L, IE-2000U-16TC-G, IE-2000U-16TC-GP, IE-2000U-16TC-G-X, IE-2000U-4S-G, IE-2000U-4TS-G, IE-2000U-8TC-G, IE-3000-4TC, IE-3000-4TC-E, IE-3000-4TC-E-INT, IE-3000-4TC-RF, IE-3000-8TC, IE-3000-8TC-E, IE-3000-8TC-RF, IE-4000-16GT4G-E, IE-4000-16T4G-E, IE-4000-4GC4GP4G-E, IE-4000-4GS8GP4G-E, IE-4000-4S8P4G-E, IE-4000-4T4P4G-E, IE-4000-4TC4G-E, IE-4000-8GS4G-E, IE-4000-8GT4G-E, IE-4000-8GT8GP4G-E, IE-4000-8S4G-E, IE-4010-16S12P, IE-4010-4S24P, IE-5000-16S12P, IR1821-K9, IR1831-K9, IR1833-K9, IR1835-K9, OM-IE-3000-8TC
