C2G Cisco GLC-EX-SMD Compatible SFP (mini-GBIC) Transceiver
Quicklinx: C5TFWS00 Mfr#: 88604
This Cisco GLC-EX-SMD compatible SFP transceiver provides 1000Base-EX throughput up to 40km over single-mode fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Cisco GLC-EX-SMD Compatible 1000BASE-EX SMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-EX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
40 km
Cisco GLC-EX-SMD
1.27 cm x 5.59 cm x 0.76 cm
31 g
Cisco 2, 20, 5760, 8; ASR 901; ASR 9000 Route Switch Processor; Catalyst 3560, 3750, 4500, 4948; Catalyst Compact 3560; Industrial Ethernet 2000, 30XX; Integrated Services Router 11XX; Line Card E-Series; ME 3600, 3600X 24, 3800, 3800X 24; MWR 2941; Nexus 93180, 93XX; Supervisor Engine 7, 7L, 8
Plug-in module
Silver
Wired
Cabling Type
1000Base-EX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
40 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-EX - LC single-mode female x 2
MSA
Cisco GLC-EX-SMD
1.27 cm
5.59 cm
0.76 cm
31 g
Limited warranty - lifetime
Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter, 2520 Connected Grid Switch, 2-Port 10GE, 20-Port GE High Queue Combo Line Card, 2-Port 10GE, 20-Port GE Low Queue Combo Line Card, 2-Port 10GE, 20-Port GE Medium Queue Combo Line Card, 40-Port GE High Queue Line Card, 40-Port GE Low Queue Line Card, 40-Port GE Medium Queue Line Card, 5760 Wireless Controller, 5760 Wireless Controller for High Availability, 8-Port (2:1) 10GBASE-T RJ-45 Half Card, 8-Port 10 Gigabit Ethernet Network Module , Cisco ASR 901 , Cisco ASR 9000 Route Switch Processor 440 , Cisco Catalyst 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3560X-24P-E, 3560X-24P-L, 3560X-24P-S, 3560X-24T-E, 3560X-24T-L, 3560X-24T-S, 3560X-48P-E, 3560X-48PF-E, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-E, 3560X-48T-L, 3560X-48T-S, 3750V2-24FS, 3750V2-24PS, 3750V2-24TS, 3750V2-48PS, 3750V2-48TS, 3750X-12S-E, 3750X-12S-S, 3750X-24P-E, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-E, 3750X-24T-L, 3750X-24T-S, 3750X-48P-E, 3750X-48PF-E, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-E, 3750X-48T-L, 3750X-48T-S, 4500 Gigabit Ethernet Module, 4500E Series Line Card, 4500-X, 4948E, 4948E-F , Cisco Catalyst Compact 3560C-12PC-S, 3560C-8PC-S, 3560CG-8PC-S, 3560CG-8TC-S , Cisco Industrial Ethernet 2000 Series, 3010 Series , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Line Card Classic, E-Series , Cisco ME 3400E-24TS, 3400EG-12CS, 3400EG-2CS, 3600X 24CX, 3600X 24FS, 3600X-24FS Ethernet Access Switch, 3800X 24FS Carrier Ethernet Switch Router, 3800X-24FS Ethernet Carrier Ethernet Switch Router , Cisco MWR 2941-DC, 2941-DC-A , Cisco Nexus 7000 Series 48-Port Gigabit Ethernet Module (SFP), 7000 Series 48-Port Gigabit Ethernet Module with XL Option, 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco Supervisor Engine 6L-E, 7-E, 7L-E, 7L-E Redundant, 8-E, 8-E Redundant
